FormD T1 v2 - PSU bracket clamp
Other FormD T1 v2 - PSU bracket clamp 1.1
The clamp for PSU bracket to solve a problem of FormD design and it works very well for me. It uses one of 6 PSU mounting holes as attachment point.
Aside from that part you gonna need a 6-32 screw with length of around half an inch (13mm).
You can take the attached STL or export from Onshape to any format you like and either 3D print or CNC it. You gonna need to register to be able to export, but it's 100% free.
Author
Zurath
Downloads
Views
1,138
First release
Last update
Rating
0.00 star(s) 0 ratings
