Finally got the case in and was able to build inside of it. The package came cut but luckily the case wasn’t damaged!
Specs:
Case: ZS-A4s v2
CPU: Ryzen 5 2600
Cooler: L9i
GPU: Zotac 2070 blower (269mm)
PSU: Delta 500w Flex atx
Ram: G.skill Ripjaws 16gb 3600
Storage: Intel m.2 1TB
The case had to be squeezed outward a tad bit to fit the gpu but it all worked out and fits snug. The psu cable was a c5 so I had to splice a c15 and the c5 together to get them working. Another odd thing was that the sell didn’t send me a Power Switch cable for the mother board so I had a make shift one until I can solder the wires to the switch.
Temps weren’t too bad, although I might need to under volt my GPU. Temps were reaching 82c while my CPU reached 50c.
Sound isn’t too bad, but the fan in the flex at does go full rpm for about 5 seconds then stop every minute or so, so I might have to swap the fan out for another.
Thanks!
Specs:
Case: ZS-A4s v2
CPU: Ryzen 5 2600
Cooler: L9i
Thanks!
