I'm a huge fan of the Magnus One.. until I get my hands on Beast Canyon, I think it's the NUC to beat in terms of power to size ratio. I love Phantom Canyon but the RTX 2060 is a tad too underpowered for 4k these days, and that power brick.. sheesh.
Excellent review at AnandTech:
I do feel like there are some essential mods you need to make to the Magnus One for it to be great. Inspired by this existing forum topic and @LukeD
First, you gotta ditch that TERRIBLE and NOISY cpu cooler for the well known Noctua NH-L9i. Pretty simple though it does void the warranty, you gotta detach that back plate to get the stock cooler out.
Second, UPGRAYEDD with two D's for a double dose of that pimpin' to a 120mm slim fan for better cooling. There's even a cool 3d-printed 92mm to 120mm adapter out there for this in the above linked thread, mine sadly didn't arrive yet because the site sent the wrong item, right now the 120mm fan is being held in by friction which is fine
Third, get out yer dremel and snips and remove the unnecessary inner part of the metal mesh on left, right, and side panels for dramatically improved airflow.
(This is kind of a pain on the top panel, you will need needlenose tin snips and patience, but on the sides, it's easy with dremel cutting disc.)
I also like to snip the rear panels but this part is optional, it's a bit of an OCD micro-optimization on my part feel free to skip this step, consider it a bonus one..
Once you do all this you get super solid airflow and .. it's quiet, even under full blown furmark + prime95, which is an ABSURD level of load you're not gonna see in any real use, it's just a smooth whirring.. I measured it about 3 inches away with a DBA meter on my phone during the furmark + prime95 (330w+ load!!) and I got around 50 DBa
Oh, and I also
- dumped the SATA drive and shifted to a single 2TB NVMe drive with a little black heatsink as well. Spinny rust! Who even uses that any more!
- of course added another 16gb DIMM so we get dual-channel memory, total of 32gb
Anyway, I _LOVE_ the Zotac Magnus One and I think it's the SFF machine to beat in terms of power to size ratio.. and once you do the above mods, you also end up with a surprisingly quiet machine, even under load!
Oh, and I also
