Resource icon
GPU Zotac 1080ti SHIFT bracket 2
Josh | NFC
Not From Concentrate
NFC Systems
1,862
4,407
www.nfc-systems.com
Josh | NFC submitted a new resource:
Zotac 1080ti SHIFT bracket - DXF STEP
CAD for PCIE Bracket replacement creation for the Zotac 1080ti mini.
This bracket shifts the Zotac 1080ti toward the motherboard in the S4 MINI to allow clearance for the HDPLEX 400AC, enabling a "brickless" build.
This can be modified to invert the gpu 180 degrees if for some reason you want to do that...
Special thanks to Tacients for getting me to actually get this done, and for ordering the prototypes and testing it in her rig.
Josh | NFC
NFC Systems
1,862
4,407
www.nfc-systems.com
Mcw83
Got on the list. Thanks for linking this Josh!
wooger0111
It says I don't have permission to download it :( I messaged the guy selling them, hopefully he still has one. Is there any way I could 3D print a bracket for myself?
