Production Z-CASE P50: Premium Console-Sized PC Case (7.9L)
BernardoZ
Founder of Z-CASES
z-cases.com
Feb 7, 2018
263
483
www.z-cases.com
UPDATE
Separate psu orders will start shipping tomorrow. Case orders (with or without psu) will start next week.
If you don't get your tracking info immediately please be patient, cuz we'll ship in small batches till end of month.
Cheers
chrimen
34
I went ahead and pulled the trigger on this case last night.
I'm still trying to understand what's the max size cooler this will fit with the included spacers less than 60mm?
BernardoZ
Founder of Z-CASES
z-cases.com
Feb 7, 2018
263
483
www.z-cases.com
CPU cooler: up to 40mm height (without glass spacers)
up to 50mm height (1 set of spacers recommended)
up to 60mm height (2 sets of spacers recommended)
chrimen
34
I noticed when I got the case I could only buy 1 set of spacers. How could I order an extra set of spacers?
By the way the case looks awesome great job!
revan
Anyone else planning to put a 3700X in this case? Whats your cooling solution, not sure the L9i is going to cut it and the 12s doesn't seem like it would fit.
BernardoZ
Founder of Z-CASES
z-cases.com
Feb 7, 2018
263
483
www.z-cases.com
There is an option on the website to add more spacers when you buy. If you want 1 extra set, send us an email and we'll figure it out.
I haven't received any notifications.
We've shipped about 20 psus this week. Couldn't send more because of mid-autumn festival in China. We'll continue this Monday, so please be patient because it can take till end of month to ship all orders.
It depends on how many sets of spacers you will use. I recommend using 1 set and a Cryorig C7 Cu.
DmanX
21
Question: is it possible to get the left side panel with a hole pattern similar to the right side for use in flat/horizontal orientation?
TimLFoss
Hey man, have you tried a mini dtx motherboard in this case? I know it's not a common size, but the standoff holes are the same as mini itx, and the board is just a little bigger vertically, which it seems this case would have room for. Any confirmation whether or not it would?
chrimen
34
Someone on reditt is using the same cooler and cpu in an s4 case and only getting max 63c gaming and in the 40s idle.
I'm also doing a 3700x in this case.
Reactions: revan
wallysimmonds
24
I had a L9a and a 3700x in my Dancase, it got pretty toasty. Ended up replacing it with a Asetek 645, much cooler now.
revan
OverclockersUK has the Cryorig C7 cu on preorder, so I'm hoping that keeps the chip reasonably cool.645 sounds nice but I have doubts I could make it fit.
BernardoZ
Founder of Z-CASES
z-cases.com
Feb 7, 2018
263
483
www.z-cases.com
Z-CASE P50 - Last Chance!
After months of pre-production, we'll finally start shipping this week!
There are very few P50 case units left, which you can purchase at:
For in-depth info on the product, I recommend checking Jay's review at:
Thanks for everyone's support
chrimen
34
I also pre-ordered this... but apparently there is an issue with the way it faces the motherboard. Also I've read it's a pain to install on AM4 boards.
Check this thread out
Reactions: revan
revan
Thanks for the heads up - seems like the bracket isn't required, it just makes installation easier. Is that your view on it also?
