Prototype X-Nuclear Triad Project Part 1: X-ICMBs
RoLexus
140
64
byanh.com
First prototype of part X-ICMB use Legofab V3 structure: ATX-C Peacekeeper:
Our website (under construction) byanh.com and minipccase.com
X-Nuclear Triad project is a ambitious project in SF world, include three part:
1. X-ICMBs : LegoFab V3 Structure, a powerful, flexible structure, can be used to fabricate almost any kind of cases.
2. X-SLBMs : Mini Hybrid cooling solution, bring a extremely high cooling performance in small shape.
3. X-SBs : Tiny PSU solution, a solid-state 400-600W PSU in single slot low profile PCIE card shape, a new chapter for PC's PSU.
In this thread I would like to introduce Part 1 X-ICMB, LegoFab V3 Structure, a powerful, flexible structure, can be used to fabricate almost any kind of cases. and a first prototype ATX-C Peacekeeper: 8.5L ATX case with 4 PICE slot, Flex ATX PSU, expandable.
So What is LegoFab?
In Version 1, LegoFab is just a simple method to connect flat metal sheet, use metal sheet only.
It's a good solution but there are some problems:
-Need thick metal sheet.
-Middle point of each sheet is easy to be bend.
-Some connection points are visible.
-Many screws are visible.
Until now, version 3 is appeared, is mix with bending method, solve almost problem of V1:
-Stronger, flexible (can easy select size), can be used for slide model.
-Simple, beautiful, low weight (Screws 5 side can be invisible).
-Can be fabricated by CNC.
Benefit of LegoFab V3 and main idea of X-ICBM project:
-Any cases are made from 5-10 same shape parts.
-Users can design any case with almost any layout that they want, use our software name "X-Creator suit" (Special made for LegoFab and Unibody Structure- on developing), thousand models will be available in library.
-Frame Material can be Steel, Aluminium, or Stainless steel.
-Part can be fabricate by bending method as the prototype or Cast/CNC.
-User can order each part of cases (To change the model or extend size without order new one).
-Many type of vent holes and side shape (example : X-Statan model).
-Price range from low to ultra premium depend on options selected.
-Other Designer can use this structure and "X-Creator suit" software to develop their cases model, we can conduct fabrication.
Note: If we start this project people who interest can select any model in the library, first time about 10 kind of cases with are launched. Prototype of some popular type will come soon.
Reactions: chyll2 and XCreator
BernardoZ
Founder of Z-CASES
z-cases.com
Feb 7, 2018
264
490
www.z-cases.com
@RoLexus Your drive link is wrong.
Also, why don't you clean your stuff before taking pics? I don't care if you are messy, but it can really give a better appeal for your products.
Apart from that, great ideas! Good luck ;)
Reactions: XCreator
XCreator
42
33
As schedule, we are going to build our workshop, web site next Spring, but it was delay a bit, he still stay at home so he decided to make a prototype and show some test results, just for information so you can see the designs are working well, not only idea or simulation.
Our resources are now limited, so that is the good thing we can do.
We are going to share drive, but not public now.
Reactions: BernardoZ
XCreator
42
33
Prototype of model X-Satan (Size S-M-L) in X-ICBMs series is coming next month to show the power of LegoFab V3 structure, Members in my country can order those prototypes with the price for testers.
Spec of X-Satan:
Size 135x305x233(L)/203(M)/185(S)mm.
Material Steel or Stainless steel, Metal color or paint, or PVD coated.
3 Side CNC transparent acrylic (4 Side for model S)
Support ITX MB, SFX, GPU ( upto 145mm height, 300mm Length), CPU cooler max height 60mm, 1-2 2.5" drive.
Remote power button.
Model L : Support 240mm AIO water cooler with 15mm or less Fan.
Model M : Support 15mm or less fan top.
XCreator
42
33
X-Topool ITX Console prototype, a Popular 6.3L console type case, smallest of this kind, portable design, 1.7Kg only is also comming.
Size 66x313x304.5, SFX/SFX-L PSU, support GPU max 115mm H, 304mm L, Support AIO 120mm (with 170mm GPU) 2x2.5" drive. Model 6.9L (66x343x304.5) support 145mm H GPU:
XCreator
42
33
Many smallest case are coming (Left to right)
1. X-Topool , Smallest popular console type 6.3L
2. X-Satan, Smallest popular 2 side tower type with water cooler 240. 9.3L
3. X-Peacekeepler MATX Smallest MATX case with SFX, full length GPU, Water cooler. 8.6L
4 X-Bularva, Smallest ITX case with Flex PSU, Single slot full length PGU. 4.3L
5 X-Peacekeepler ATX FX , Smallest ATX SLI with water cooler (up to 240) and SFX PSU. 12.5L (Dark picture)
chyll2
431
362
Wow big update. You really love water cooling. Do you have the cpu cooler clearance for these?
Xenos
21
Looking to build my own with at local shop with a cnc: could you opensource your cad for the community?
