You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
I'm after basically any case that uses the mobo and GPU back to back with a flex atx psu underneath layout, a custom mod mini would be acceptable. I'm also open to picking up a warhead mini if I can confirm the radiator support.
