Windowed version with 1080 Ti Strix
Dawelio
Awesomeness
503
427
Hey guys,
I was just wondering if there's someone in here that might have an windowed NCASE M1 with an ASUS 1080 Ti Strix inside of it?...
Cause I've found this image, but it's an 1080 Strix and the 1080 Ti Strix is a bit thicker than the 1080, hence wanted to see if the "ROG" text logo on the front side of the card actually shows through the window. Or if it will be too far down and hence be covered instead, and thus, how much in this case (no pun intended).
Thanks,
Dawelio
VegetableStu
1,946
2,607
it'll fit in there, just that you can't fit regular case fans under the GPU afterwards (except for slim ones)
(there's mounting for a complete 3-slot card in the M1, so your use case would be covered, until you consider those bigger than 3-slot)
EDIT: oh dang misread the part on the window. let me go have a look again ,_,
VegetableStu
1,946
2,607
okay take 2: did some visual comparisons and there might be a high chance it'll be hidden ,_,
wait for people who own an M1 and a strix 1080ti to confirm though
(full image link, WARNING: LARGE)
