Motherboard Which mATX motherboard will fit in the CEMO 9001
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
2,801
4,127
guilleacoustic.wordpress.com
I guess it would fit mATX with only 2x DIMM ... but double check motherboard dimensions before ordering as it's very not standard.
Below are mATX motherboards with 2x DIMMs (note the variation in width and height)
  • Asus PRIME H310M-C/PS R2.0 : 9.6 inch x 7.6 inch ( 24.4 cm x 19.3 cm )
  • Asus PRO H410M-C/CSM : 9.6 inch x 8.2 inch ( 24.4 cm x 20.8 cm )
  • Asus EX-H310M-V3 R2.0/CSM : 8.9 inch x 7.0 inch ( 22.6 cm x 17.8 cm )
  • Asus PRIME H310M-E/CSM : 8.9 inch x 7.3 inch ( 22.6 cm x 18.5 cm )
Reactions: dupsiii
dupsiii
Sorry i forgot to mention that i need a am4 mb *
Resellers dont mention the size every time, or maybe there is a website where i can check them all ?
GuilleAcoustic
LOSIAS
Jun 29, 2015
2,801
4,127
Gave those boards as an example, it's only a coincidence that they all are Intel one ;). Most brand allow you to filter on form-factor an number of slots, that's what I did on Asus website.
You'll have to go to the "tech spec" tab on the product page for that. That's where I found the ones I mentioned.
Also, if you don't need more than a single PCIe ... just get a regular ITX board since you'll only have 2x DIMMs anyway. Not that many AM4 "narrow" mATX boards ...
Reactions: dupsiii
