What software to use for case design.
Bourne3D
Hi guys, I'm working on a case design but I am not familiar with the high end CAD software such as SolidWorks or Autocad.
I would like to be able to make prototypes too so I ask what software do you recommend to make 3D prototypes and something that could be sent to a 3D printing service?
Reactions: andornaut
outtatheblue
You can try tinkercad.com for a web CAD tool that's on the simple side. I've made some case & panel prototypes on there and then printed them at home afterward. The site offers output file formats that printing services can use.
Windfall
2,117
1,577
Personally, I would recommend Autodesk Fusion 360.
It's a good solid modeler with solid sheet metal tools, good direct and parametric modeling options, and a built-in render and animation workspace for sharing your ideas.
It can import most of the models in SFFn's Resources section, and is incredibly easy to learn.
Anyone who is semi- computer literate can learn the fundamentals in half an hour.
If you would like, I can send you some key tutorials that really helped me with case design,
and I'm online enough I can help should you have any questions.
(Autodesk did not pay for this plug, I'm just a VERY satisfied user.)
Also, please reference the STX.160 guide linked in my signature, as it's an epic resources that @Aibohphobia spent a lot of time on,
and can answer questions faster than you can ask! :)
The issue with tinkercad is it's so limited. It's good for basic stuff, but it lacks sheet metal tools and good export functionality.
I keep hoping it gets updates, but if you want a modeler of that type, Sketchup is a far better option. Just my 2c. :)
Reactions: Bourne3D
outtatheblue
Agree w/ the opinion on tinkercad being limited. It really leaves much to be desired if you try to do more complex designs or just need more functionality. Will check out Sketchup and Fusion 360 based on your recommendation :)
dc443
57
Where do you guys find decent 3D/CAD models for components? I'm having moderate luck on sketchfab and grabcad, but it seems like a real crapshoot.
Reactions: nerdbit
Windfall
2,117
1,577
Grabcad has a lot of decent models imo, but if that isn't working then you can check out SFFn's own resources section, has a lot of good models!
robbee
n3rdware
760
1,099
Sketchup's 3dwarehouse also has lots of models that can be imported to most CAD programs. Although they're generally not as high quality as the ones you'll find on Grabcad.
dc443
57
That’s awesome, thanks! I‘ve been using Shapr3D on my iPad and I completed a custom design for the side and front panels for my next build with it. the software let me import one model (and i wisely did it with a Vega Strix card). it got me through the job. What a nice piece of software.
dmznsdp
25
I want to switch to something more sophisticated than SketchUp as it is buggy and it's painful to work with complex geometries. I've tried Fusion 360 — again, a lagging piece of software that has a permanently established connection to Autodesk. I want something with good UX like Fusion 360 has and it should support parametric design. Could you please name something that suits my requirements?
