What Power Brick to use for PICOBOX 500w
6,670
One that can do 500w.
To be honest, we need more information - what's your budget, are you willing to run dual bricks, etc.
KMPKT
3,382
5,934
I'd go for a pair of these:
http://www.meanwell.com/webapp/product/search.aspx?prod=GST280A
The one thing to consider about external bricks is they can go ~10% higher than rated wattage before things start to fail. If you plan to aggressively push the 500W limit on the Pico, then odds are without ample overhead you may blow one or both of your bricks. 280 X 2 = 560W + 10% = 616W peak. This is likely enough overhead to manage large momentary spikes without losing any of your hardware.
