What is the smallest case to fit an RTX 3070
wedgevic
Heya
I am planning on building an SFF rig that is as small as possible and still has an RTX 3070 (any kind as long as it is a 3070) and a 5600X in it. What is the smallest case that can fit one? Right now I have the Velka 5 V2 in mind. Any suggestions?
Thanks!
SFF Watercooled
398
172
Heya
Thanks!
Velka 5 rev 2.0 is the smallest for sure, that is if you are comfortable with 45-degree riser bends, rerouted I/O, and a FlexATX PSU (They sell a black 600w FlexATX for just $100 bundled with a Velka 5 rev 2.0, and $139.99 sold seperately)
Here is a list of 3070s that will fit in the Velka 5 rev 2.0:
GPUModelBrandNameLength (mm)Width (mm)Height / Thickness (mm)SlotsPCIe BracketBoost Clock (MHz)Memory Speed (Gbps)TDP (W)PCIe PinsFansDisplayPortHDMI
NvidiaRTX 3070 8GB GDDR6AsusTurbo26911240221755142002x8131
NvidiaRTX 3070 8GB GDDR6Inno3DTWIN X224012040221725142208231
NvidiaRTX 3070 8GB GDDR6Inno3DTWIN X2 OC24012040221740142208231
NvidiaRTX 3070 8GB GDDR6LeadtekWinFast AI BLOWER26611139221725142202x8131
NvidiaRTX 3070 8GB GDDR6MSITWIN FAN23011543221725142206+8231
NvidiaRTX 3070 8GB GDDR6MSITWIN FAN OC23011543221740142206+8231
NvidiaRTX 3070 8GB GDDR6NvidiaFounders Edition242112402217301422012231
Keep in mind the MSI Twin Fan is NOT the MSI Ventus 2x
Blower cards are okay but not recommended
Pretty much the only card that is on sale is the Nvidia 3070 Founders Edition
Tute
80
56
Smallest case in absolute terms - Velka 5.
Smallest case without making cable management a complete nightmare - Dan A4, ZS A4/A4S
Smallest case without using a riser and allowing for a decent sized CPU cooler - SGPC K60
Smallest case without using a riser, allowing for a decent sized CPU cooler and without using Taobao - Lazer3D LZ-XTD, Sugo SG05/06/13.
wedgevic
thank you so much!
wedgevic
thank you so much!
Diamorif
211
105
I just finished a 5600X/RX6800 build in the ZS A4S V3. Its like a smaller version of the Dan A4 and the build quality is outstanding. Its a bit bigger than the Velka 5 2.0, but you can use a Black Ridge and cable management is a bit easier. If you're cool with a flex atx PSU, I would reccomend this over the Velka and the Dan
Reactions: wedgevic
wedgevic
Thnks man, Ill check it out!
