As the title would indicate, I'd like to know the exact hole spacings (and also diameter) of the mounting holes for a 140 mm fan/rad. I'm looking into making a small-ish AIO that needs a 75x75mm to 140x10mm adapter. But given the width and height of the fan itself is 140x100 the mounting holes would be smaller and I need the dimensions to create an accurate bracket with.
Thanks in advanced
Thanks in advanced
