Enclosure Vertical Cases
cattlebaron
I have been looking to move to a vertical SFF case like the Hyte Revolt 3 or similar. Anyone used the Revolt? The SSUPD Meshroom? Any others that are recommended? I am looking at stuffing a Ryzen 7 7700x or similar in it and an AMD RX 6950XT or similar. My current setup is a Fractal Meshify 2 Compact.
ExtremeDetailer
In my experience, it would be any SSUPD. They are well planned and allow for good airflow. Maybe the Hyte is a better layout for dustfilters if you need longevity, in terms of needing not to clean. But maybe I think you would like the SSUPD more. I don't know the dimensions so consider this as direction help.
btw, I think this document might help you decide:
