Unnamed —ATX full watercooled 18.4L—(X99,5820k,5700XT)
jrx3810
The case which have enough room for 240+120 radiators always looks huge. But only 240mm radiator is not enough for both CPU and GPU
So I attempt to put 240x60mm +120x30mm raditor into a case as small as possible.
At last the case size was 336x287X191mm
It very quite also temperture is well controlled.
INTEL 5820K
MSI X99 GAMING PRO
CORSAIR DDR4 3000 16GB (4G×2)
SAPHHIRE 5700XT
WD BLUE M.2 500G+WD BLUE 2.5" SN500 500GB +WD 3.5" 2TB
RADITOR: alphacool UT60 240+ST 30 120
FAN: GT 2150 X3
CORSAIR SF750
DDC PUMP
FRONT :
BACK:
FRONT without cover:
Compare with a4 case in software
3dmark : cpu was oc at 3.6Ghz and GPU 2150Mhz . temperature are well controlled at fan 800rpm pump 2000rpm
