Ultrathin DisplayPort Internal extender?
Windfall
2,117
1,577
Like this:
https://aerialpixels.com/shop/audio...dard-right-angle-flat-ribbon-cable-40cm-15-7/
Except displayport.
Going to connect to a wx4100, so mini (or micro?)
Does this exist?
If so, where?
Thanks, Windfall.
chx
547
281
No. It doesn't. I looked far and wide and for a very long time, there are no thin or flat DisplayPort cables.
Sashby
71
105
Reactions: Phuncz and BaK
BaK
855
868
These ADT-Link products look good, thanx a lot @Sashby !
Do you guys know if there is a standard for ports orientation on GPUs?
Like, let's say you have an horizontal GPU layout and you want the DP cable to go down thanks to an angled extension. And let's say you need a left angled extension to do that on your GPU.
Will a left angled extension always be okay to have the cable going down on any GPU card?
chx
547
281
Windfall
2,117
1,577
Just an FYI. These flat HDMI 2.0 cables are better quality for anyone interested (4K@60Hz)
https://adt-link.aliexpress.com/sto...302.html?spm=2114.12010614.0.0.463c7751LuZDwl
As for flat right angled Displayport short extension cables, I haven't been able to find any except these angled Displayport cables (mDP included) 0.3m
https://adt-link.aliexpress.com/store/group/DisplayPort/3659032_514262424.html
That one on the bottom would work too, but the link doesn't link to them.... It opens a login page.
If you could get a working link, it would be very appreciated!
Also, to the rest of you, thanks a ton for your help!
BaK
855
868
Reactions: Sashby
