Other Ultimate PPL? DFI Ryzen embedded SBC, Rpi size
2,201
2,225
Thought this might be of interest to some people here:
84*55*17.4mm, though that seems to be without a cooling solution. Max power consumption equipped with the highest power SoC is 21W.
Anandtech said:
DFI has announced what they consider the world’s smallest single-board computer (SBC) that uses on AMD’s Ryzen Embedded processor. The highly-integrated credit card-sized GHF51 motherboard can be used for a variety of applications that have to be small, yet offer capabilities as well as performance of a modern PC. The DFI GHF51 1.8-inch platform carries AMD’s dual-core Ryzen Embedded R1000-series SoC with AMD Radeon Vega GPU featuring three compute units (192 stream processors) with hardware H.264, H.265, and VP9 decoding. The SoC can be paired with 2/4/8 GB of single-channel DDR4-3200 memory as well as 16/32/64 GB of eMMC storage. The SBC features one Mini PCIe slot for an add-in card, an 8-pin DIO header, two micro HDMI 1.4 outputs (4Kp30), one USB 3.2 Gen 2 Type-C port, a GbE connector (controlled by the Intel I211AT or the I210IT chip), and an fTPM 2.0 chip. At present, DFI lists two AMD Ryzen-powered SBCs: the GHF51-BN-43R16 with the Ryzen Embedded R1606G APU (2.60 GHz – 3.50 GHz, 12 W) as well as the GHF51-BN-43R15 with the Ryzen Embedded R1505G APU (2.40 GHz – 3.30 GHz, 12 W).
Reactions: galzy and Jello
