Update 19-4-2016:
Latest main frame design:
18-4-2018:
Change design to unibody, Dimension: 280x186x100mm, inside: 272x178x96mm:
Main frame:
18-4-2018:
Main frame:
Tired with duplication idea? Today I will show you a design that you never seen before: Tiny-Rex ITX.
Tiny-Rix is ITX case only 4.7L (inner), specifcation:
-Inner dimensions 296x176x90.
-Max graphic card size : Length 298mm, Height 42mm.
-Max CPU cooler height : 37mm.
-Support Flex ATX PSU.
-Support 1x92mm front fan.
-Structure 2mm stainless steel sheets with LegoFab connection method, it makes case to be smallest, easy to fabricate, good cost and high quality.
It's really small and cool as well, size is same with graphic card box!!
MOD EDIT: Removed clickbait title
