Production Throw out your PCIe Extender ! WH-Micro gaming PC
WH-team
102
186
rahulkiit
Can you provide details of Dimension and some internal pics. Is this case available for order with international shipping.
WH-team
102
186
Tech Specs
Dimensions 225H x 125W x 315L mm (including case shell)
Weight & Volume 1,2 Kg & 8.8 L
Material 3 mm aluminum liner & 1.8mm steel shell
Colors : black, silver gray
GPU compatability : Dual-Slot, max 305 mm without bracket
mb compatability Mini-ITX
PSU compatability SFX, SFX-L, FLEX
CPU cooler comp. max height 55 mm(without fan, use wind tunnel)
AIO Support : 240 AIO+ dual 12015 fan/120AIO+single 12015 fan
Memory comp. max height 55 mm
PCIE connector : Warhead Original PCB
rahulkiit
Tech Specs
How to order this case. what is the cost
Nosuchthing
51
53
Are there internal pictures with the different layouts? Can I use a 240mm AIO as well as a full size GPU and SFX PSU?
ignsvn
By Toutatis!
1,621
1,538
Just curious, do you have any temperature & noise benchmark?
Stylis10
Can I make a suggestion, make a form for this case and the other case, where we can pledge to buy as you had said in your other thread viability is only there if a min order of 50 is met.
WH-team
102
186
ahhhh......sorry everyone in China this time must have a rest:) I will update liner structure inside tomorrow:D:D
Kandirma
54
40
Interesting riser solution to still allow some airflow in that link
And the...hot glued(?) power supply input is an interesting choice.
Total volume seems to come in ever so slightly larger than the A4-SFX, but seems to be setup for multiple 80mm fans?
WH-team
102
186
sure. I will make form about my cases. and shipping cost about different area. now I making links on eBay. and I will build another forum for order :)
WH-team
102
186
these data I will update soon, now new 240 AIO is on the way. I will make a build log and publish photo. including temp and noise data,
WH-team
102
186
yes. Micro`s volume is more bigger than A4-sfx. It`s about 19% enlarge. but it could install 2*9015+2*9025 in normal mode or 240 AIO+2*12015 in AIO mode.(two different type liner). New connect mode is friendly with M.2 SSD. and PCB is more reliability. A4-SFX as a gaming PC. it`s CPU temp and bad airflow I think is bad to Long time operation of hardware. so I removed cooler`s fan and pull up the cooler`s height to the 55mm.
like L9X65/TC12LS/AXP-100 can be installed. and airflow from bottom to top. Just like the server processor uses in the heat sink mode. The air flows vertically through the radiator to take away the heat, and the vertical airflow direction ensures that the heat will not return to the air as other machines that inhale on both sides
Jello
375
161
Have you done temperature testing using this setup?
