Hi guys,
I'm planning a build for this fall (4700x + 3080ti or AMD's top end) and was looking at the usual case candidates like the M1, but then I stumbled upon this :
The Metalfish G5 is nothing new as I've found people talking about it on reddit a few months ago, but there seems to be a variant, this "watercooled version". It adds the space to fit a 240mm radiator, max height of 55mm (with fans I assume) which is pretty good.
It seems to check most of the boxes for a potential good case for high end hardware :
- good ventilation
- room for 2 extra full size fans at the bottom
- compatible with 240mm AIO, with full size fans
- good GPU compatibility (300mm long, 55mm thick)
- As a bonus it's made of machined 3mm thick alu, so transporting it shouldn't be too stressful
In a smaller package than the M1 as it's 11.6L, and only $150. The M1 is 20mm wider so the G5 is definitely worse for air cooling the CPU but if going the AIO route it seems to be a viable alternative.
The one thing that turned me off was the shitty acrylic panels but there is even a full alu version for $15 extra :
So, opinions?
With most small ITX cases having very limited availability I'm seriously considering just getting this one, it might not quite reach the build quality of a LOUQE but it looks very serviceable.
- good ventilation
So, opinions?
