Discussion Thermalright AXP-100 Full Copper measurements
Tonkatsu
77
43
Heyy. Anyone got more complete measurements of it? Thermalright's own aren't thorough enough.
Here's what I'm missing;
Trying to figure if it will fit on an ASRock Phantom Gaming-ITX/ac
https://smallformfactor.net/reviews/asrocks-z390-phantom-gaming-itx-ac-a-new-direction/
tinyitx
Shrink Way Wielder
Jan 25, 2018
1,871
1,720
3 comments:-
a. I bet, the 2 missing dimensions are just the same as the regular non copper version.
So, try the full listed dimensions here. The 2 dimensions are there.
b. The vertical dimension in your diagram is 27mm, which is exactly the same as the non copper regular version.
A pic in this review shows the figure '27' in the installation manual
c. A guy had actually installed this cooler into that particular mobo (Asrock Z390 ITX). It fitted.
