Production Sliger SV590 and SV540 - Vertical SFF Cases!
KSliger
Sliger Designs
May 8, 2015
855
3,186
Oh so it's painted steel now for all 3 panels? any samples of how it's gonna look?
See above, looks better than anything else I've made IMO.
Is there enough clearance for something like the Swiftech Drive X3 with the integrated res on the 590? I can't quite tell from the images of the case.
Negative, will have to go custom loop.
@KSliger If I wanted to prep and order custom cables from @pslate for the SV590, what length & bend cables should I order? Trying to get all my ducks in a row.
Looking forward to the preorder! Thanks for all the continued hard work!
I will get @pslate a case to start taking measurements ASAP.
emo.83
Teaser of the new matte black SV finish!
SV510 will probably happen next year.
SV540 will bump up slightly to add 3-slot GPU support, this change will make the 2-slot SV510 make more sense.
That looks phenomenal. Adding 3-slot for the SV540 is also nice. Can't wait!
youngdocument
35
Thrilled about triple slot support for 540!
Might have missed these answers in the thread, apologies if so:
1. Is there any support for case fans in the 540 to get more airflow throughout? Mainly thinking of my m.2 drive, which heats up a lot.
2. What’s the current vent design looking like? I’m a huge fan of the large vent gaps on the SM series. Lots of airflow and still gives you a peek inside at components.
Sashby
71
105
Wouldn't the SV540 as a 3 Slot make it wider than the SV590? It's going to look chungus without any curved/angled edges on the front panel (SM5XX).
It'd be +170mm wide (due to the 75mm CPU cooler height + 3 Slot)?
KSliger
Sliger Designs
May 8, 2015
855
3,186
1. There is no plans for additional fans. I would recommend flipping the SFX PSU around so that it pulls air from middle of case / back of motherboard. This will help the airflow for any back of board M.2 drives.
2. Same as in renders, spent way too long working on patterns and this one is the only one that didn't feel overly generic or look like it was trying too hard.
I totally support 3-slot coupled with 70mm+ CPU cooler clearance. Allows very quiet components, which I think is ideal given the fact these cases are likely to be quite close to the user.
Design change is keeping it the same size, but the center spine will have 3 positions
55mm CPU cooler + 3-slot GPU
65mm CPU cooler + 2.5 slot GPU
75mm CPU cooler + 2 slot GPU
This should give excellent flexibility for maximizing space use for most builds.
Unfortunately anything that needs 3-slot and >75mm cooler would make more sense in an M1 due to the 170mm rule, as per @Sashby's comment.
HYPERBOLOCO
35
Could you boost the width 5mm so you could do a 60mm CPU cooler 3 slot or a 70mm Cpu cooler 2.5 slot?
That would allow for some more heavy duty cooler combos like the AXP-100 Pure Copper or Noctua NH-L12S for the 3900x ?
Reactions: vduong143
maxdfw
Smol Form Factor
Aug 21, 2019
55
60
Beautiful. I love the top power button.
vduong143
But at 65mm CPU cooler + 2.5 slot GPU, you could do Alpenfohn Black Ridge + slim 120mm fan. The 80mm clearance with 2 slot GPU would also allow 25mm fan for Big Shuriken 3, not sure if the size increase is worth the extra performance.
youngdocument
35
Would the ID Cooling IS-60 be the best CPU cooler at a 55mm max height, then?
edit: movable spine sounds awesome. Sidearm T1 style making an appearance.
HYPERBOLOCO
35
My suggestion was to allow 3900X support at all GPU positions. The AXP-100 CU and Black Ridge / NH-L12S and Shuriken 3 are tied respectively.
TubePunk
Can you please tell me if the SV 590 will allow for a motherboard that is 20.3cm in length? I'm specifically referring to the ROG X570 Impact (Mini-DTX). It is the same width of 17cm as standard mini-ITX. Am I correct that the additional length at the bottom of the DTX board would be cutting into the max clearance for the radiator, or is the bottom of the board oriented towards the front of the case?
DrHudacris
918
1,720
2 problems:
-The extra length extends towards to the front of the case, according to the renders.
-SO-DIMM riser card on the impact is 82mm high
