Part Streacom ST-HT4 Thermal Riser
aquelito
Piccolo PC
Feb 16, 2016
948
1,116
Hi there,
I need the exact dimensions of this particular piece of hardware.
Thanks by advance for your help !
6,591
That^
Unfortunately the unit I have is in use in a server of sorts..lol
aquelito
Piccolo PC
Feb 16, 2016
948
1,116
Thanks to both of you.
I sent an email to Streacom support.
aquelito
Piccolo PC
Feb 16, 2016
948
1,116
Yep, I got some rough dimensions :
Hole to hole dimension is 48mm
Aluminium block dimension is 56 x 56mm, 6mm thick
Height is 35mm +/- 1mm
Width (including heatpipes) is 76mm +/- 1mm
Reactions: Goatee
