Smaller that itx?
P2theG1
I suspect that I already know that what I am after does not currently exist but I shall ask anyway
Can you get a motherboard smaller than itx but that still supports PCI E for a GPU and has a Ryzen7 or i7 compatible socket? I am looking to get a board that is no taller than 140 mm
Thanks
P2theG1
Yeah, you can get a mini-stx board. It doesn't have a pice slot, but it can have m.2, which you can expand to a full length slot.
Check out this awesome build by @Aibohphobia here: https://smallformfactor.net/forum/threads/stx160-0-the-most-powerful-atx-unit-in-the-world.934/
Thanks for that I am looking into making a functioning Razer Project Christine but I need a Motherboard smaller than i+x otherwise I will have to make a system inspired by Project Christine with a slightly larger Main Part to support a mini- itx board
