Figured I'd post my Sliger SM560 custom build log over here. Going to be running a XSPC Tx240 radiator with single Noctua NF A12x25, Ek Velocity cpu block and gpu block.
Test Fitting block and Radiator
Made a custom bracket for DDC pump and Alphacool Eisdecke Brass Top and Alphacool Flow Metere as Reservoir (Thanks Goatee)
8.16.19 Today I worked on the pass through and drain port - Need to paint bracket for the Bitspower Through Hole Fitting - Pretty happy with how everything turned out.
