giraffesinmybalcony
95
88
guys, imho it would be better if you guys came up with other names that arent based on the Greek mythology as it was with the Cerberus. Cerberus is designed by Chimera Industries and hence it does not make sense or a good decision to name the SM550 based on the Greek mythos since it would only confuse consumers more.
Reactions: Arboreal
Arboreal
807
806
Absolutely, I was thinking the very same thing yesterday, and was intending to post about it. You have said just what I wanted to.
If only I could think of a decent name for them...
Solo
858
1,431
I don't know, but Dominator Platinum's are absolute skyscrapers at 54.79mm.
Alur
119
122
Any updates on SM560? congratulations, they surely look amazing, pretty curious about the SM560 model most of honestly.
KSliger
Sliger Designs
May 8, 2015
855
3,186
Apologies on delays on launch, business customers bought up the entire production before I could launch. Waiting on a shipment of risers from China and we're going live!
Also might make a vented window with launch - does this first picture look good?
There's also the 3-slot wide GPU version in that album, it has 65mm CPU cooler height. Might be handle with bifurcation for 2 slot GPU + capture card.
jkiejr
82
31
I like the vented side panels, bit still prefer the slats on the top. Like in this pic
Reactions: JaPeMo
f1recracker
This looks so good! Will you be making both 2 slot and 3 slot versions? Does the 2 slot have extra CPU clearance?
If the 3 slot has 65mm cpu clearance, then could I have even taller CPU coolers with the 2 slot variant?
Edit: To answer your question - I kinda prefer the vented panel especially if it helps with thermals!
KSliger
Sliger Designs
May 8, 2015
855
3,186
Ok, I'll change back to this vent for the 2 slot version. Easier to make anyway. 3 slot will stay the new design.
2 slot is 55mm CPU clearance, meant for C7, L9i, Wraith Stealth, and LP53 setups.
3 slot is 65mm for Noctua L12, Scythe SCSK-1100, SCBSK-2100, etc. with room to spare for window or unvented panel to not choke it out.
giraffesinmybalcony
95
88
imo the side cutouts at the top and side panels are overkill. if it was just cutouts at the front portion it would look great, but when its throughout the side and rear, it ruins the overall aesthetic of the case
Reactions: xcrco
AJA
Oct 14, 2018
So, I have some questions:
1. Will the dual slot version still support a 2.5 slot or 51mm GPU like my Cerberus 1070 TI or do I have to buy the 3 slot version?
2. Will both versions still be available in red?
3. Any idea on prices for the two versions?
4. Lastly, when can we expect the cases to be available to buy?
This is the case I've been waiting for, so hopefully it's not too long now. Thank you for your hard work on the case.
KSliger
Sliger Designs
May 8, 2015
855
3,186
They look great in person, and they mask when panels are not completely lined up. Trying to keep it classy looking but still "aggressive" looking compared to the standard Lian Li / Jonsbo look of every other SFF case.
1. Dual slot will fit only 2 slot cards, up to 42mm thick. (max is 47mm, but that is right up against side panel.)
Three slot will be the better choice for wide card.
2. Yes! White, Black, and Red, possibly a beige color in limited quantity.
3. Both sizes with vented panels, $199. Windows add $10 per side.
4. March 1st, be on our site. NewEgg shortly after.
Glad you like it, sorry it took so long to get made!
giraffesinmybalcony
95
88
Ah that's understandable, and might i add, a very simple and creative solution for minor panel misalignment! I guess it's a matter of personal preference and it seems that other users are liking this current design, which is great :) either way, hopefully we'll see the Cerberus on Newegg along with this case in March
Reactions: anoldfriend
teodoro
109
77
Noctua lists the L12 at 66mm, will that fit in the 3 slot version sans bending?
I know the cutoff has to be somewhere, but I’ll still bring up that the L12S (at 70mm) should net ~3-10 degrees better cooling than the 92mm only L12. Personally that equates to better noise as the fan can spin a bit slower. The S model also seems to be more widely available (and/or cheaper, $5 on US amazon and $20 on NewEgg).
KSliger
Sliger Designs
May 8, 2015
855
3,186
I'll bump it up to 70mm for L12S and Big Shuriken 3, nothing really exciting around 60 to 65mm.
