KSliger
Sliger Designs
May 8, 2015
855
3,186
SM550 (2-slot GPU)
9.7L @ 335mm x 139mm x 208mm
  • Up to 55mm tall CPU coolers
  • dual slot GPU up to 310mm
  • 2x 120mm fans in bottom
  • Can be configured for semi-passive cooling configuration with GPU and CPU fans removed
  • Starts at $180 USD + shipping
www.sliger.com/products/cases/sm550/
Thermal Testing Results
SM560 (3-slot GPU)
11L @ 335mm x 159mm x 208mm
  • Triple slot GPUs up to 310mm, or bifurcated riser for dual slot GPU + 1 slot PCIe card (Network/Capture/Sound/etc.).
  • Starts at $190 USD + shipping
www.sliger.com/products/cases/sm560/
SM570 (240mm AIO, 2 Slot GPU)
13.9L @ 357mm x 135mm x 287mm
  • Up to 55mm tall CPU coolers or AIO water cooler pumps
  • 1x 240mm or 2x 120mm AIOs in top of chassis
  • Dual slot GPU up to 330mm
www.sliger.com/products/cases/sm570/
SM580 (280mm AIO, 3 Slot GPU)
15.9L @ 357mm x 155mm x 287mm
  • 1x 280mm, or 1x 240mm, or 2x 120mm AIOs in top of chassis
  • Triple slot GPU up to 330mm (even MSI Trio X and Zotac AMP cards will fit!)
  • 2x 140mm fans in bottom
www.sliger.com/products/cases/sm580/
Ambushes
49
32
Looks great, although the front panel looks kind of plain as it's just a completely flat panel screwed onto the front. Any idea on availability?
KSliger
Sliger Designs
May 8, 2015
855
3,186
This is awesome, the handle is very useful. In for red when this comes out.
Handles are mandatory on cases now in my opinion.
I agree, will see how the prototype comes out looking and see if I can come up with anything nicer looking at that point. Flat was just to be inexpensive, which it does really well, and also so it could be stood up on it's front face (feet mount on bottom or front) but it's... kinda silly looking upright (need a removable cable cover) and over laps market with @DSE 's case.
Also, this could easily be made into a vertical case :D
Haha see above per standing it on the front face. I love desk space.
Looks good, what is your cpu cooler clearance?
50mm so anything that's Dan A4 compatible plus a little more. (I got a LP53 and a Noctua fan to test with)
gunpalcyril
294
319
@KSliger I was actually about to buy your handle for cerberus to use on DSE's case lol.
Also, if you use non-sfx-l psu and only sfx, and also cut out the support frame section underneath, is there a possibility to use a 120mm aio in this case? :eek:
KSliger
Sliger Designs
May 8, 2015
855
3,186
I'll check with DSE if he has handle support on current rev.
That's a great idea for a change, I'll see what I can do.
Screw-less front cover would be aesthetically better to me.
It's a possible change, would need to flip the BSO's on the chassis to be from the front panel and screw in on inside of the chassis - which would entail reversing the SKC cutouts for the side panels to slide in from rear via cutouts in the flange bends. Would also eliminate the ability to have a grained aluminum front as I cannot grain BSO's.
I'll take a poll on screws or no screw once I have prototype in photos.
5,837
4,906
It would be interesting if this would support vertical orientation, but not on the front face but on the rear, so all cables exit on the surface of the table and at the rear (bottom of the case in horizontal orientation). You could make an optional kit for this that mounts to the frame (in black) and allows feet to be attached. This way the clean sides would all be visible while the more "unclean" sides (bottom and rear on horizontal orientation) are hidden from plain sight.
And you'd have your distinguishing feature.
gunpalcyril
294
319
This. Seriously the first case maker to get a vertical oriented itx case done right is bound to make waves.
Reactions: Phuncz and DSE
Marwan
125
125
Looks cool. you can probably, make the outer shell CNC aluminum and bended with cutouts for your I/O and you'll have IMO a more aesthetically pleasing looking case.
m-i-c-k-e-y
63
64
Suggestions:
- Rotate the power supply so that it has its own air intake from the sides.
- If its me I will widen the case a bit and make it three slot and add a Pci Slot HDD bracket accessory.
- understood why you placed the outlet on top, BUT if you placed it at the bottom (and run a longer cable) you could a. free the top for taller GPUs b. by raising the pcie slot a bit you could free the bottom for potential HDD space?
Best wishes to your design.
NFSxperts
112
53
yah! Finally another case with a handle. Hopefully it'll get past the prototype stage.
Maybe its because of the pics, but I think it resembles the Cerberus too much for me.
Also, I agree with placing the power plug at the bottom since most gpu coolers blow heat out at the top.
From my experience of carrying around my SG05,I find that weight becomes an important factor.
And sharp corners aren't good if you're gonna be moving around frequently.
Reactions: Arboreal
jkiejr
82
31
this is nice, like a mini cerberus. i like the reversible psu and the ability to mount a 3.5 drive on the bottom.
