SLI on ITX motherboards with PCIe Bifurcation
LukeD
Case Designer
Jun 29, 2016
465
1,202
Here is the tutorial for injecting SLI certificates into ITX motherboards with PCIe Bifurcation capabilities.
There's no need for silly driver workarounds, works with Nvidia drivers out of the box.
PDF: LINK
UPDATE: I can confirm that the process is exactly the same for z390 boards and someone also validated that x470/x570 also work
UPDATE2: Asrock Z390 Phantom Gaming-ITX/ac includes an SLI certificate by default (no need to inject for this board)
I'm leaving the below for reference but its just personal notes. Not required for Intel anymore.
For Intel the process is slightly different because the UEFI / BIOS is in a different format. I'm trying to find the tutorial file I wrote up, however if I don't, here are the high level steps for Intel boards:
dump aml from z270 donor board using clover (f4)
convert aml to dsl using:
iasl.exe -oa dsdt.aml
Open dsdt.dsl using MaciASL
Copy SLI license key to clipboard
dump aml from z270 recipient board using clover (f4)
Paste in SLI license key
Exit
use iasl to convert dsl to aml using:
iasl.exe -oa -f dsdt.dsl
LukeD
Case Designer
Jun 29, 2016
465
1,202
No I haven't. I posted about this in the past but never got around to posting it up.
I had a few people contact me via twitter asking for the instructions, hence I'm posting them up.
I had a full guide written for z170/z270 boards as well, but I left in on my NAS in Australia, so its unattainable for me in the foreseeable future.
Windfall
I'm a huge fan of SFF
Moderator
Nov 14, 2017
2,109
1,569
That is mildly disappointing, but shouldn't be too much of a roadblock.
LukeD
Case Designer
Jun 29, 2016
465
1,202
I can also report something VERY interesting ...
Looks like ASrock listens to their enthusiasts needs.... SLI is enabled with a Temp key on the z390 ITX motherboard out of the box:
ermac318
650
503
Luke, is that the z390 Phantom Gaming ITX board? If so, how could I see if mine has it?
LukeD
Case Designer
Jun 29, 2016
465
1,202
This is the board: LINK (Z390 Phantom Gaming-ITX/ac)
@ermac318 You can check by download AIDA64 Extreme and once you open AIDA do the following:
Report -> Report Wizard -> Next
Hardware-related pages -> Plain Text -> Finish
Once the report generates, do a text search for SLI.
If it shows up it means the certificate is there.
Reactions: ermac318
ermac318
650
503
Well I'll be damned, there it is. That's quite the find!
TristanDuboisOLG
81
21
Hell yeah they do! I was actually the one that called them up and requested a custom x99e-ITX bios last year. Even after this long they still were happy to make one for me! I love Asrock! ♥
fabio
Shrink Way Wielder
1,850
4,266
Ho is possible that on my Asus X570 Crosshair Impact DTX the certificate is present as well??? Ho can I SLI if the boards doesn't support bifurcation??
That's curious!
LukeD
Case Designer
Jun 29, 2016
465
1,202
You can’t SLI if the board doesn’t support bifurcation.
You need both things .... bifurcation and sli certificate for SLI to work
fabio
Shrink Way Wielder
1,850
4,266
Good to know!! I will check my Gigabyte!!
ermac318
650
503
In theory you could get a riser with a PCIe Switch... but I dunno if that exists.
Reactions: fabio
ermac318
650
503
Anyone know if there’s a list of z490 itx boards that are sli certified?
None of them are officially. It appears that some z390 boards have "temp" keys installed. No one would know unless the bought the board and did the testing that LukeD described. Maybe ask some folks in build threads that have a 10th gen CPU to run the test?
@LukeD - do you have any indication of what other boards might have SLI keys?
xkruz
61
105
Hello, Can I use SLI certificate from different brand? Like asus x570 sli cert for gigabyte x570 or even asrock z390 for gigabyte x570?
Since i have asrock z390 itx, asus x570itx and gigabyte x570i itx ?‍♂️
Reactions: fabio
AP2
264
295
safe to say, if a board is bifurcation ready all we need to do is inject the SLI key from a donor board (if SLI temp key is not there) ?
DrHudacris
752
1,459
Very odd problem that I'm running into... DSDTEditor refuses to open any AML/DSL file I throw at it. Tried extracting/dumping AMLs from 3 motherboards now, and even tried running the DSDT editor batch file on 2 different machines, and in all cases I get "Unmatched brackets, tree not updated" error, and AE_ALREADY_EXISTS
Anyone know what could be going on? It's gotta be an issue with the DSDT editor right? It's somehow not dissassembling/parsing the AML correctly?
