Production SLATE-CASE AQ >>Status Update - Factory Orders and Progress
Baka
post from dondan himself on the C4 forum regarding 4x series sizes
NameSlotsLengthHeight
Asus RTX 4080 12GB ROG Strix3.15336???
Asus RTX 4080 12GB TUF3.25305???
Asus RTX 4080 ROG Strix3,5357150
Asus RTX 4080 TUF3,65348152
Asus RTX 4090 ROG Strix3,5357150
Asus RTX 4090 TUF3,65348152
ColorFul RTX 4090 BattleAx3326140
ColorFul RTX 4090 iGame Vulcan3,25340145
Gainward RTX 4080 Phantom3ca. 315ca.137
Gainward RTX 4080 Phoenix3ca. 315ca.137
Gainward RTX 4090 Phantom3ca. 315ca.137
GIGABYTE RTX 4090 AORUS MASTERca. 4ca. 350ca. 160
GIGABYTE RTX 4090 GAMING OC3.5ca. 330ca. 150
GIGABYTE RTX 4090 WINDFORCE?????????
INNO3D RTX 4090 iChill X33.25336146
INNO3D RTX 4090 X3 OC3336145
MSI RTX 4080 12GB Gaming Trio3ca. 330ca 140
MSI RTX 4080 12GB Suprim3,5ca. 340ca. 140
MSI RTX 4080 12GB Ventus X32,5ca. 305ca. 140
MSI RTX 4080 Gaming Trio3,25ca. 330ca 140
MSI RTX 4080 Suprim3,75ca. 340ca. 140
MSI RTX 4080 Ventus X33ca. 305ca. 140
MSI RTX 4090 Gaming Trio3,75ca. 330ca 140
MSI RTX 4090 Suprim3,75ca. 340ca. 140
Nvidia RTX 4080 FE2305137
Nvidia RTX 4090 FE3305137
Zotac RTX 4080 AMP Extreme3,5355,5166
Zotac RTX 4080 Trinity3,5356165
Zotac RTX 4090 AMP Extreme3,5355,5166
Zotac RTX 4090 Trinity3,5356165
  • Love
Reactions: N9neBreak3r
TaylorChiller
Super Magical Detailer
206
627
At that point why not just make them all true 4 slot cards and not as long? Even many full sized cases can't support a GPU that long, especially if using a front aio/rad. At least they are in time for winter, gotta need that extra space heater.
firassasin
with double rads has anyone tested the best setup thermally? is it exhausting from both the front and back or is it having the air go one directions through?
Pagusas
32
30
has EK announced water blocks yet for the 4090's? many of the partner cards are over handing the heatsinks by a large margin, the actual pcb is much smaller than the the heatsink (on some of them). So the waterblock demension will be way smaller length wise than the stock HSF configuration.
Just look at how much of the ASUS card is HSF:
Basically an entire 1/3rd of the card is just heatsink overhang. the water block size will likely be in the 270mm range.
XNine
85
98
No one has done any real thermal testing in this case that I've seen (there's only been 2 reviewers to see it), especially not with dual radiators, though with conversations I've had with Taylor it sounds like like making them both exhaust is the optimal solution.
TaylorChiller
206
627
The dual rads I setup worked well as exhaust. I can see them working as both intake, but you should ideally have two perf panels when 100% positive pressure in this scenario.
TaylorChiller
206
627
If you do one direction flow, you will be recycling air. At high fan speeds this will probably be fine, but not ideal. Flow through air is best when using a single rad.
6ixty9ine
I was looking at your youtube video and was wondering if it'd be possible to fit in small/slim fans (say 80mm, 92mm?) on the perforated side of the case (assuming single perf panel). Was thinking of mounting them using bonding tape or similar. Would help to make the dual intake work better.
crxss
TC was right, FEs are 304mm. 4080 FE is also 3 slots, unfortunately.
Baka
here are 2 so far. they look kind of meh honestly and not as good looking as the 30 series one. hopefully heatkiller can save the day with a better looking design.
TaylorChiller
206
627
I mounted 92mm fans using those rubber fan mounts. I'd recommend NA-Sav3 or NA-Sav4 from noctua. Or something similar. Some come double sided for various ways of mounting, just trim off excess.
XNine
85
98
Not likely for FE cards, unfortunately. I would have killed to have a HK block for the 3080FE. Or Aquacomputer for that matter.
Gmoney
41
44
The only 4090's on that list I'd consider are the Strix, TUF, Suprim and Gaming X Trio but none will fit due to length. Or maybe there is 3mm wiggle room to fit the Gaming X Trio. What's missing from that list is the 240mm rad AIO cooled MSI 4090 that is 280mm in length which would be a perfect fit for this case.
At this point its either FE or that liquid cooled MSI. FE I really don't think is ideal in these vertical cases because of all the heat that gets exhausted underneath.
diegopx
2 - FLT120 is hard fit. Only way to make this one work I think is placing it where the rads would go, or if you use the trad layout, but that limits your rad space ( for now). The FLT80 should fit fine along side your waterblock (I have that same waterblock)
In regards to the fit for the FLT80, would it matter if it is the DDC or D5 variant? I’m having a bit of trouble visualizing this arrangement and want to make sure I don’t order the wrong type. Thanks!
Baka
You'll have to go the WC route for a lot of those to fit in most SFF cases. The EK Strix waterblock looks to be 238Lx148W but now it's aslo recommended to get a new PSU too according to jayztwocents. fun!
Gmoney
41
44
Yeah I have 0 interest in going water. I change hardware so frequently that its just not viable taking apart loops/blocks constantly as I resell/swap/upgrade.
Also jayztwocents is an idiot. I'm using a SF750 with my 3090 Ti which has higher transient spikes than the 4090 according to Nvidia's material here:
My PSU has no issues running my 3090 Ti full tilt along with a 12900K for gaming purposes and I'm using a 3x8pin to 16pin cable from here:
Pagusas
32
30
Looks like some of the third parties are using 4x 8pin to 16pin adapters… wonder when we’ll see those offered by vendors.
TaylorChiller
206
627
DDC would be best for this
TaylorChiller
206
627
Update here:
I'm not sure why, but customs release for this last warehouse shipment is taking longer than expected. I'll keep you all updated. My gut tells me we may start delivering orders late Sept and into Oct.
Taylor
