Skyreach 4 MINI Vertical Case Stand
Enclosure Skyreach 4 MINI Vertical Case Stand 2019-09-15
seven7thirty30
142
249
seven7thirty30 submitted a new resource:
Skyreach 4 MINI Vertical Case Stand - S4M Vertical Stand
A 3D printable vertical case stand for the Skyreach 4 MINI case from NFC. There are two versions. The "Slim Version" is for the standard case dimensions. The "Wide Version" is for the 5mm extension to each side panel as seen is the build log at the link below.
This was designed to be used with the machined aluminum case feet from NFC, but I imagine that any case...
n13L5
51
I'm also thinking about making feet for mine, but I think I'll give it a tilt, by making the front legs taller than the rear.
making sure any beer or other liquid will exit post haste...
