Prototype Sion V2: A simple approach to Console Cases
Sorakamii
109
49
Temps look good, I'm assuming they're for under load?
What's the issue with the cable management? Is there not enough space for the cables as they are now, or do they not bend into the positions you imagined for routing?
For the GPU mounting, I think most of them have something for the riser cable to screw into, so the PCB can add support, plus the retention screw by the back plate. Is there a spot for the retention screw on the back plate?
As for SSD placement, behind the GPU might not be the best place given how hot that can get and the GPU issues you're having. Is there enough space on the front panel to mount them there?
The case itself looks really good, I especially like the way the RGB shines through.
1. Yes the first image shown is under 30 minute load with prime 95. My ryzen 5 3600 was at all stock settings (the voltage was high but thats a ryzen 3rd gen problem i need to fix in bios.) My room was around 75 degrees Fahrenheit or 23.8 Celsius.
2. Its a bit of both,i need to pay around with how im routing them before i assume its the case,but at the same time the 24 pin is a nightmare to route.
3. For the gpu im considering adding another screw hole in the back panel that'll hold the bottom in place while the bent area in the back holds it up. I need p continue to play around with he hole placement back there too.
4. There isn't enough space to mount it up front as of now. Im currently looking into another way to mount them without them interfering with the power button cable and psu cables like they currently do.
Ill be heading up to a machine shop in the morning to get a few on the easier parts done, then I'll head back and continue editing the design.
Sorakamii
109
49
Small update:
I'll be ordering some new L-Brackets next week to secure this case to itself. Other than that,i've been playing/using the PC all day today with the new case and i can say it looks and feels nice. I'm going to change the support back to slim fans since (judging from my cable management in this small space) its kind of dangerous to use full sized fans. I'll also say that the fans behind the GPU are definitely putting in work since i Overclocked my Ryzen 5 3600 to 4Ghz at 1.3 volts and the temperature hasnt hit over 62 degrees celcius. My GPU has an idle mode where the fans wont spin unless its under real stress,and i can note that all three fans have never been on at the same time. My room has been roughly 22 degrees celcuis all day today.
Sorakamii
109
49
Good morning everyone, after building and rebuilding my case i came to a few conclusions. Theres alot of little things within the case that annoyed me to death while i was using it. The number 1 biggest thing was the small L-Brackets that i had to constantly keep track of,or risk them coming loose or falling off on me. This prompted me to rethink the design a bit and i came up with this.
The entire right side has been redone. I fused the L-Brackets and top panel to the right panel that way everything you need to attach (minus the GPU) will go on here. After attaching everything,the front and back can be attached only by lining up the holes on the right panel. NO MORE separate Brackets needed. With that changed,the next question is what happens to the left panel.
Here the left panel is smaller and can slightly swivel open,should you need to just slightly open the case. There are 1.5mm gaps between the front/back and side panels for more air and to allow this swivel. Video here.
The last update was the GPU hold-down bracket and the SSD cage. The reasoning here was that since i couldnt stop the power supply wires from going through the SSD are and making them a bit unstable,I'd make an actual cage and reduce the SSD capacity to 2 here...or 4 if you want to deal with the cable clutter. Now they will be more stable and i can use the cage as a tiedown point for the other cables. Next,the GPU holder, its just a small piece of metal that'll hold the GPU straight against the backpanel. No much to say there.
Little things like the PCIE cable i have being a little stiff isn't something i can fix. Fan cables getting caught in the fan is a cable management problem i should've noticed.
Tell me what you think
Sorakamii
109
49
With these recent changed,it costs $100 less to make this prototype versus the previous one. It is safe to assume this will translate to the final product being cheaper to produce. If my assumption is right,and my math is correct,i may be able to use the same company i used to make the prototype and be able to get the case out to the consumer in half the time. Please take this with a grain of salt,but should this work,i may be sticking with the version 2.
Edit 07/28/2020
Shipping always gets me,so im back to the other company i had talked to. Shipping will still take roughly a month.
Sorakamii
109
49
August 03,2020 Change
  1. Moved GPU Placement up by 12.5mm
    1. Gave more room for PCIE cable and SSDs
  2. Moved Fans and SSDs up by 7.5mm
    1. Gave more room for Power Supply wires
  3. Expanded SSD cage by 10mm.
    1. This should allow power supply wires to slide between the ssds and allow better cable management while also keeping the 4 SSD slots that i wanted.
Sorakamii
109
49
Personal Update:
I have completely switch over to the new case and have been using it for the last 3 weeks as my main rig. I have to say i love it not only since im the one that designed it,but i actually notice the large amount of extra desk room i have to just throw stuff around. Its much more silent than my previous rig and i almost forget that its there.
