Prototype Sion-The Thicc 10 L Console Case
Sorakamii
87
44
Table of Contents:
  • Concept & Goals
  • Case Specifications with Part Compatibility
  • Design
  • Survey, and other important details (Please fill this out)
  • Timeline & Next Steps
  • Changelog / Tl;Dr
Concept & Goals
Sion was designed to hit a balance between 3 main goals:
1. Premium build quality, look, and feel with a machined Aluminum enclosure.
2. Compatibility with widely available parts (ITX motherboards,full length 2.n slot GPUs, and SFX power supplies
3. A final price of $150 USD + shipping
Specifications:
Dimension: 325 x 336 x 92mm
10.6 liters volume
Motherboard: Mini-ITX
Power Supply: SFX
Graphics card: Dual-slot, up to 315mm length, Up to 2 slot open-air GPU
CPU cooler: up to 72mm height
Storage: 4x 2,5” SSD/HDDs – 4x above the PSU (up to 15mm height)+ M.2 HDD
Fans: 2x 120 mm behind GPU
Front panel: Premium power switch (16mm anti-vandal)
Materials: 3mm Brushed Aluminum
What's included:
Chassis, stand, PCIE cable, internal power cable, power switch, screws, standoffs, L Brackets and A set of SSD Cages
Ventilation Options.
  1. Bars
  2. Slots
  3. Circles
  4. Custom (email me directly)
Front,Top,and Bottom Panel Options
  1. Clean
  2. Custom (email me directly)
  3. Bars
  4. Circles
  5. Slots
Please note: take this list with a grain of salt until I have a working prototype to verify everything.
Design:
It will have a minimal design,unless you decide to get the custom ventilation l.I also want the case to be is easy to mod,should you want to do so.
This Prototype (WHITE ONE) is an outdated design. I finally got the shipment today (06/08/2020). There are many changes that dont show here. The next prototype will be a current up to date model that shows a better representation of what the final product shall be.
Survey, and other important details:
Design Update Poll: https://strawpoll.com/4g52rzeb
Go Fund Me:
https://www.gofundme.com/f/blacklig...dium=copy_link&utm_campaign=p_cf+share-flow-1
Indiegogo:
Timeline & Next Steps:
As of 05/15/2020
, the order has been placed for the first version of the Sion case. I ordered it in a white powder coat, and i will upload pictures of the finished product as soon as it arrives.
  • More Fan mounts
  • Possible radiator support.
    • I know this one is almost impossible,but i have seen some 80mm radiators...though i doubt they'd be able to effectively cool much of anything.
  • Cable Management Area
  • Different Stand (Cleared)
  • Possible Handle
  • Getting rid of the 2 slim fan slots and pushing the gpu closer to the side panel.
    • This should allow for regular fans to fit in front of the GPU. These would probably be best as intake since they will be bringing air that could cool the SSDs,GPU and motherboard VRMs possibly.
Thank you all for all the support.Once that first design comes in,should it all work,I'll be starting up a kickstarter/indiegogo for anyone interested in preordering the first batch. The final sale price i'm going for is $150 plus shipping (with everything listed above included). I want to somehow personally thank those people,I'll be looking into a way to do that.
Changelog / Tl;Dr:
  1. May 02,2020
    1. Fused the top and left side panel into a single part. Did same for Right and bottom panels.
    2. Created a new bracket inside the case for easy assembly and disassembly.
    3. Added the new SSD bracket for an additional 2 SSDs. (Total of 8 now rather than 6)
  2. May 08,2020
    1. Removed the middle frame
      1. I felt this part was unnecessary single its only purpose was to hold the ssds. Now they have been mounted about the power supply and should interfere with anything else.
    2. Added a small bracket at the back where the GPU will be screwed into.
      1. This may change down the line,but first i need to test how well this works on its own.
    3. Changed the ventilation pattern and face plate
      1. I got rid of that anglular design and the RGB that i wanted in the case. Im not going for a gamer"y" ascetic. I want this case to look professional while also being something you can drop some decent hardware into it and game.
    4. June 08,2020 prototype only shows the previous changes.
  3. May 16,2020
    1. Changed the stand to be one closer to that of the Sentry 2.0
      1. This was unintentional and i didn't realize it until after i changed my order. The final stand that comes included with the case will be different, I just need to sit down and think of a better design.
  4. May 24,2020
    1. Changed the project name from Yama to Sion (i like this better now)
  5. June 02,2020
    1. Changed the stand (needs to be 3d printed otherwise would be very expensive to machine)
    2. Moved the 2nd fan slot over 60mm (Now should very easily exhaust hot air from GPU and SSDs.
    3. Changed the L-Brackets. (Now should give the case much better support internally)
    4. Pushed the motherboard back 5mm
      1. CPU Cooler height has been increased to roughly 66mm
  6. June 05,2020
    1. Increased the width of the case to 92 mm.
      1. This in-turn increased the size to 10.9L (was 9.9)
      2. Increased the fan size behind the GPU to 25mm Regulars fans (was capped at 15mm)
      3. Increased CPU Cooler Clearance to 71mm
        1. Can now fit the Scythe Big Shuriken 3 (with included 15mm fan)
  7. June 06,2020
    1. Shrank the length of the case to 320mm (was 325mm)
      1. Case is now 10.6L (was 10.9L)
      2. Now fits GPUs of 315mm or under
  8. June 08,2020
    1. Changed to brushed Aluminum
      1. Will no longer have color options
      2. Price is now $150 (was $160)
  9. June 09,2020
    1. Added an extra bar on each side panel to improve stability
    2. Doubled the amount of space each SSD is from one another
      1. There are some thing you can only realize during building. The SSDs were far too close to one another and the SATA power cable i had refused to bend that much. With this massive increase in space,they should be just fine now.
I very excited to hear your feedback.
Thank You,
Shuaib
Shatrod
147
174
Why not prototype out of acrylic or mdf to test real world fitment, and then once you're happy with it and everything fits the way you want move up to the aluminum?
Sorakamii
87
44
Ya see,I'm stupid and since its Ramadan for me, I don't have the energy for higher brain functions.
Shatrod
147
174
I think white would look nice. Especially on a colored base, like an orange one. Looking at your renders it does have a flat base right?
Have you considered getting rid of the ssd cage behind the GPU and making the whole thing significantly narrower? 8ssds is kind of excessive in my opinion and I think you could make that 368 dimension more like 336. Smaller and a little more space efficient :)
Sorakamii
87
44
Yes it is a flat base, might make that out of acyrilic for color options. 8 ssds is excessive yes,but the main reason its that long is that i was thinking of triple fan gpus. I'll still look into it though. I always welcome ideas especially since im starting this case line solo
Shatrod
147
174
I understand wanting maximum compatibility but there are few gpus that are that big. Like with 315mm clearance you can likely still fit quite a few models of the flagships? I'm just saying maybe it would be an okay compromise especially since the airflow design looks good
Reactions: Sorakamii
Sorakamii
87
44
I'll keep that in mind, thank you for the ideas. It means alot to me that someone else is interested in this project
Reactions: Shatrod
Sorakamii
87
44
Looks like the max i can get it with enough space to work around with on the inside (to my liking) is 325mm so that brings it down to 9.945L in volume.
Reactions: Shatrod
Shatrod
147
174
Have you considered other vent patterns? How will you color the aluminum? Paint? Powder coat? Anodized?
Sorakamii
87
44
I did 3 different vent patterns. The angular one,bars and circles. The angular one is mostly for me since i really like it but hey should someone else want it,im not going to stop them. I plan to powder the aluminum flat colors. Anodizing is also something i may play with.
Sorakamii
87
44
Been a while since i been this excited. Placed the order this morning.
Order:
  • White Metalic Powder Coat on my Aluminum
  • Orange/Yellow Power Button.
I'll end up modding this case down the line but this is a great start.
Reactions: Shatrod
SplittingHUNTER
Order:
any pictures of the white case??
Sorakamii
87
44
Went ahead and updated the Original Post to clean up this thread a good bit
