Enclosure Silverstone Milo 10 (ML10) 2.8L or 3.7L chassis
AlexTSG
562
537
www.youtube.com
Silverstone has announced an SFF chassis with a replaceable top cover which allows for a 2.8L configuration, or a 3.7L configuration. While the standard 2.8L is fairly limited, the 3.7L top allows configs with an optical drive, 3.5" drive, or 140mm fan.
This looks like an interesting option for the upcoming AMD 4000 Series APUs.
Ziyan
Power supplyDC board + external AC adapter (sold separately)
Does anyone know more about this? I can't find the DC board anywhere, and I'm curious if it's enough for a 4700G system. This looks like a great DeskMini A300 alternative, being slightly bigger, but much more flexible.
AlexTSG
562
537
www.youtube.com
I'm not sure which one Silverstone is referring to, but if you want to go with a 4700G, and have some power reserve for overclocking, then this HDPlex 200W unit should be sufficient. They do have a list of suitable external AC adapters for it on the "Hardware Compatibility" tab.
If you don't need that much power, then there are some PicoPSUs like this one:
