I just discovered that Silverstone has launched this ITX case first seen in 2018 Computex. The design follows FT03/Mini's vertical airflow.
Personally, I am quite fond of this airflow design. It sits at around 25L though. If it can shave off some width/depth/height and makes it under 20L, I will be more interested.
www.silverstonetek.com
SilverStone LD03 INTRODUCTION
As a modern encore to the award-winning FT03-MINI, SilverStone created a sophisticated and expressive follow-up with the Lucid LD03. Instead of having an always reserved styling with aluminum side panels, the LD03 has the ability to present itself in two distinct appearances by use of tinted...
