#Silver Briefcase
doP
Hello Guys !
I'm here for one reason : SFF build :)
" Internal organs " :
I7 8700
CORSAIR DDR4 VENGEANCE LPX 16GB 2400mhz
gigabyte z370n wifi
noctua NH-L9i
samsung pm961 polaris 512gb nvme - 3000MB/1150MB
hd plex 400
dell 330w
anti vandal blue ring power switch
Skyreach 4 MINI (i will get it in 2 days)
Periferics : redragon visnu keyboard
sound blasterx siege m04 mouse + sound blasterx alphapad
iiyama g2530hsu monitor
So next step is to buy the gpu, but here i need your help guys.. Can dell 330w power brick handle a 1080ti mini ? Or i need to go with 1080 mini ? Everything will run at stock freq.
Many thanks in advance.
Come soon with building pics.
kulbida
63
50
Hello Guys !
I7 8700
gigabyte z370n wifi
noctua NH-L9i
hd plex 400
dell 330w
330w is not enough to power a 1080 Ti. You will be fine with a 1080, though.
Looking forward to seeing your build.
ChainedHope
306
459
1080 mini would be a safe bet. You can "manage" with undervolting the 1080ti but your better off just getting the 1080.
Another option is to drop the dell brick and get one of the high wattage meanwell bricks. They can do the 1080ti with no overclocking but you need some active cooling over the picoPSU (a fan is enough, some small RC car heatsinks will also work if you can't get enough airflow).
doP
And now i waiting for gigabyte 1080 mini...i didn't find zotac. Are so overpriced thx to miners...
I will check temps & noise with stock cooler..maybe i will swap with some aftermarket fan.
Reactions: Atremo
2,668
2,792
I would be happy if I could find the Gigabyte 1080, can't find one anywhere for decent price.
doP
it's seems when a start to play a game, after 1-2 min pc is restarting...
Any advice ?
alexep7
184
139
Power supply. Did you end up buying the 1080 or the 1080 Ti? If it's the 1080 that's either a defective brick or a defective HDPlex...
doP
it seems that if i limit CPU to 2 ghz and run prime 95 & furmark does not restart again .. if i run separate prime 95 & furmark with cpu at 100% everything is working fine when i start to stress both is restarting. .
so is dell brick or plex ?
