Prototyping Sidearmd T1, CNC + AIO + 9.35L
pwnedundies
27
33
discussing it internally.
the case is already severely discounted, a $10 discount will prob be the most we can do, not sure how it will be received by customers.
From the pic posted it looked like the issues were mainly internal and not really noticeable. I would personally take a slight discount all day long for the same functional product, mowing that it had issues, to get it. I buy used cases all the time. As long as it's known I don't think you have issues selling b-stock cases. I bet you could easily sell all 50 day one.
Reactions: PBJ
hetvler
60
51
I'll be honest... I can't even see anything wrong in the two pictures of the messed up anodizing lol.
Vaux
39
If it's still possible, you should move the PSU cable to the right or on top of the gpu to allow DTX motherboard compatibility
PBJ
154
100
@Wahaha360 I know the side panels seem to slide into rails in the top and bottom panels, but how are they held in place? Do they snap on the front panel or something?
schn1tt3r
118
208
If you put in a DTX motherboard, then there is no space for a radiator... asuming DTX even fits. My understanding is DTX form factor isn't supported on sandwich layout cases.
hetvler
60
51
Also I just realized the accelero 3 is like 30mm longer than the Morpheus...
Clocks in at 288mm long. Morpheus2 is 254.
I believe this case allows for like310mm long cards though so it should be alright.
DrHudacris
118
98
Which DTX Motherboard did you have in mind? Impact has a 80+mm SODIMM riser card, forget about it. Then there's the issue of standoffs; the MB tray would need a completely different set of stand offs lower down, as the extra height of the DTX form factor is directed up (using the picture @Wahaha360 posted). To use the same standoffs as an ITX Motherboard would leave the extra height of a DTX board sticking out of the top of the case. Not to mention the PCIe riser card would likely need to be a bit longer. Many have dreamed about DTX in a sandwich layout, it is just not practical to adapt an ITX sandwich layout to accommodate a DTX.
Reactions: Shinken1
Vaux
39
Nevermind, I forgot that the motherboard was upside down, that would have worked if the aio space was on top and not on the bottom
DrHudacris
118
98
Sure, the MB would physically fit. But the issues related to longer riser cable remains. That extra length of the riser cable would need to be stuffed somewhere when a mitx mobo is used. And again, SODIMM riser card (if crosshair impact is being referenced)
Vaux
39
Well people can buy their own riser cable, I don't really see that as an issue ( it's like 30€ if I'm not mistaken), and my point was more to add a feature to the case with minimal effort
For the impact, the so-dimm module is optional
Reactions: DrHudacris
blorkborkey
Is is still possible to use a 240mm rad? and could it be done with a 27.5mm thick one?
Im fine with shaving a little bit off some parts if that would help...
  • Haha
Reactions: Floris
blorkborkey
here we go again...
ONLY the Eisbaer LT240 is supported as far as 240rads go.
sorry if i missed something... didn't want to read through the 80 pages of forum. Is the problem just clearance for the height of the rad? In that case, I could just use a 12mm fan from scythe or something else that is thinner than 15mm, right?
