Prototyping Sidearmd T1, CNC + AIO + 9.35L
newzealot
Hahaha, at this rate, there will probably be people calling for two tone "black and space-grey" and two tone "black and silver".
Those sound incredibly cool, but at this late stage of the project, i would prefer faster release of just any colour :)
Demon Boy Jr
77
108
That sounds interesting. Do you know of anyone with info on temps with the AXP-100 Full Copper + A12x25 combo?
I have one and could get a more direct comparison against an L12 for you if you'd like. I could do something like the Ghost S1 with the side panel off since the Axp-100+A12x25 wouldn't fit with it on.
I'm pretty busy this week though and probably wouldn't be able to publish anything until this weekend or next week though.
Reactions: PBJ
bobgr8
Hey, first time post here, looking to build a SFF, first SFF PC also. Would this be a limited run? Also would it ship to India? Thanks!
thekinghippo
38
61
A bit sad the I/O made its way onto the two-tone. Having no power button on the front makes sense going for complete minimalism at all costs, but far less sense with a damn SD card reader. Thanks for planning to offer the I/O-less upgrade kit in 2020.
PBJ
132
87
If one opts for 2-tone will the mesh side panels be sold aftermarket at a later date?
Silver mesh panels are planned for 2020
@chyll2 @chinyang @Wildmongoose @Metroversal @Brude27 @JayRello @sffman @prava @PBJ @GerryMz @Beardedswede @Bonusround @schn1tt3r @Navic
This is the current *plan, things happens, so can't promise
Year 2019:
- $200 Black *base version, Ultrafine Mesh Side Panels, NO I/O, August 2019 if Quality Control perfect, most likely September 2019
- $240 Two Tone Version, Tempered Glass Side Panel (SFX fan facing inside the case), I/O, December 2019
Year 2020:
- Silver Aluminum Side Panels with holes
- Black Aluminum Side panels with holes
- Silver Ultrafine Mesh Side Panels
- Black I/O Front Lid for Black *base version
- Silver NO I/O Front Lid for Two Tone version
Some of you will notice that the Two Tone version with TG Side Panels should make temperature worse, and you will be correct. This is why I added 240x25mm thick radiator support so you can still get <85C with TG keeping CPU OC < 160W. For those of you that want to mix different Side Panels types, you can in 2020.
Reactions: Allhopeforhumanity
PBJ
132
87
That would be great if it’s not too much trouble, take your time.
THE_KRAAKEN
I still don't totally understand the 240 AIO compatibility. So would it fit a 240 x 30 AIO (Fractal Design S24) with a thin fan in front and normal fan at back?
Navic
36
34
No. For you to fit a 240mm AIO, you would need the radiator to be 25mm thick, and have a 15mm slim fan at the front and a normal 25mm thick fan at the back
