Prototyping Sidearmd T1, CNC + AIO + 9.35L
PBJ
84
66
So, who’s decided which version they’re gonna get? It’s so hard for me when both look so good in their own way! 😓
Beardedswede
182
155
Om afriad that the mesh will be to weak with indent or not. Or at least very sensitive. But then again I guess can just buy some spare mesh parts if you sell that as well. That would be nice.
chinyang
both mesh versions looked good to me. personally i like the one with the indent.
just wondering if the indent will actually had any impact on CPU cooler clearance, i.e. if i put a noctua L12s, the CPU cooler will touch the mesh
schn1tt3r
94
189
What fans do you recommend instead of the NF-A12x15 and NF-A12x25? I just can't bring myself to buy them for the color alone. Which are the 2nd best (that also make a slim 15mm tall version)?
EDIT: No RGB please
PBJ
84
66
EDIT: No RGB please
How about the Scythe Kaze Flex fans? I think they’re pretty good.
The slim version is kind of hard to find in the US for some reason though. Only place I could find it just in case:
https://www.aerocooler.com/scythe-su1215fd12h-cnp-kaze-flex-120-slim-fluid-dynamic-bearing-120mm-x-15mm-pwm-fan/
Reactions: schn1tt3r
Wahaha360
Overhaul
SFFLAB
NCASE
783
2,459
no, it will not affect CPU cooler height.
AP2
115
102
EDIT: No RGB please
Look at prolimatech slim vortex fans. High static pressure and black in color. 120x15
theexplainer
21
EDIT: No RGB please
I thought I read something about noctua releasing black versions of their fans, including the A12, in the first quarter of 2020
Rapide
Finally ordered lt240, will I need any modification with this or it will fit out of box? (Except fans ofc).
And as I understand any RTX AORUS/Strix/Evga cards will fit w/o problems, but msi trio willnt fit, am i right?
gwertheim
104
64
The Alphacool Eisbaer 240LT is already a perfect fit it this case, so I see no need as to why they'd need to dedicate resources to develop that
Americans are having trouble getting the 240LT and if we can get a better pump which could potentially help with thermals, why not try.
It's not only for this case I am thinking about but for all itx cases, current and future. Big picture
