    Votes: 116 24.7%
    Votes: 353 75.3%
  • Total voters
    469
scatterforce
408
325
I love the direction this is going. The build I envision:
NhL12-s
3600x
2 slot RX3080 (or whatever AMD announces tomorrow)
SF 600 platinum
120x25mm Fans exhausting at top
I'm more comfortable with air, but will use that rad space for bigger fans.
vpri
41
There needs to be a point where you say we can't support everything, it would defeat the purpose of the form factor.
That being said, this will be the first time playing with watercooling so I am kind of excited for this
That's true. There are already many limitations that come from adopting ITX / SFF. I noticed though we're all putting powerful stuff in our SFF cases, that's why I think there is something to be said about supporting 240mm AIO, even if it's only the AlphaCool LT240, I'd be ok with it.
EMBIGGEN!
That is... I am perfectly happy to see this grow slightly. I feel it might give better options for positive airflow with a rad exhausting up top.
Yeah I agree, although let's not forget this is @Wahaha360 project. I'm eager to hear what's next.
NhL12-s
3600x
SF 600 platinum
Not sure the power consumption on that CPU, we'll see tomorrow, but it seems it might be running hot.
Esso
Absolutely, agreed. It's feedback if anything... I've become a positive air snob over the years :)
I'll admit, I was provoked by one of your previous posts on the matter: "I wonder what the majority of users here think about it." ;)
scatterforce
408
325
Well, looks like my build will be mid summer at this point. I want to wait for a 3000 AMD CPU. And Vega 7..... Looks a bit more power hungry than I expected. At least Corsair has it covered with the SF 750 psu. But so much heat
Tazpr
553
429
Now this is a cool case, not sure if it's enough to pull me away from the Thor Mjolnir, but I certainly appreciate the internal layout decisions!
Reactions: dlal1520
Brude27
384
878
I don't know how I managed to miss this project, but I'm really diggin what you're doing here! Obviously it's tough to say this early in the game, but if this project is successful... will you do more than one run? Or is this only planned as a one-off kind of project?
QuantumBraced
507
358
I love it. Again, the only issue I have is the limited clearance for the bottom intakes, I'd love to see 10mm feet or something like the Streacom DA2 or maybe just 2 wraparound "feet" in that style, don't know what the term is for that but hopefully you get what I mean. For a case that relies on bottom intake for all CPU/GPU cooling, I think it's worth giving it a bit more room. Yes, you can flip it, but it should work well in both orientations.
PBJ
358
546
I believe the case feet just haven’t been added to the renders yet. Perhaps they will be added after the design and layout have been finalized.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
CES 2019, special thanks to 3lfk1ng for thermal testing and volunteering his Ghost S1 + 26mm Top Hat.
240mm AI0 might be unecessary - the Koolance HX-CU420V radiator and Noctua Sterrox fan combo is so impressive on the i9-9900K.
Test Setup
SideArmD Project Prototype 1
Intel i9-9900K + Asus Z390 ITX
Fr33Flow 48mm CPU Block + Pump Prototype 1
Koolance HX-CU420V Radiator (120x30mm, 30FPI, *Copper)
Noctua Sterrox Fan (120x25mm, one mounted on Koolance radiator, one beneath motherboard)
Nvidia RTX Titan
Samsung 960 EVO SSD
Results
Ambient temperature probably around ~25C
WITHOUT OC, CPU-Z stress test max temperature ~65C
OC all 8 core to 5ghz, (unstable & ran out of time to test more), ~85C
* there is no side panel on the CPU side (it was late, prototype 2 is more relevant for benchmark)
* case in pull mode, where radiator is on the bottom, 5mm feet
* thanks to 3lfk1ng, |||, PlayfulPhoenix, 3feetcat, for helping despite insane schedule during CES
Prototype 2 revision
move PSU and GPU upward to allow better airflow from fans, so temps should be better
add cable mgmt clasps
PBJ
358
546
Really exciting to see pictures of a prototype after seeing renders. Looks so good and the components seem to fit nicely. What model of Koolance radiator was used?
Looks amazing. Keep it up!
Alur
119
122
We may not even need the 240mm AIO. because Koolance radiator and Noctua fan combo is so impressive on i9-9900K.
This is impressive news! waiting for the temp results and all the information you can share! :p
Reactions: fabio
fabio
1,885
4,325
Eager to test it! I am in the Streacom DA2 with a 240, same MB and CPU than you! Which Rad are you using?
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Test Setup
Nvidia RTX Titan
Samsung 960 EVO SSD
Results
