Discussion Short Antenna Comparison with Benchmarks
PLLovervoltage
21
Summary
Antenna​
Default Asrock​
Super Short (20mm)​
Short (30mm)​
Geometric Mean​
213.8​
189.4​
198​
Percent Perf​
100​
88.6​
92.6​
Note: Derived from Transmit/Receive benchmarks
Detailed Result (Tested using iperf)
Signal Strength (%)
Antenna​
Default Asrock​
Super Short (20mm)​
Short (30mm)​
1(2.41GHz)​
88​
87​
86​
11(2.46GHz)​
88​
88​
88​
36(5.18GHz)​
87​
85​
87​
100(5.5Ghz)​
87​
86​
86​
161(5.80GHz)​
88​
88​
87​
Transmit (Mbit/s)
Antenna​
Default Asrock​
Super Short (20mm)​
Short (30mm)​
1(2.41GHz)​
53​
48​
58​
11(2.46GHz)​
70​
71​
80​
36(5.18GHz)​
437​
356​
360​
100(5.5Ghz)​
393​
392​
392​
161(5.80GHz)​
369​
270​
268​
Receive (Mbit/s)
Antenna​
Default Asrock​
Super Short (20mm)​
Short (30mm)​
1(2.41GHz)​
84​
86​
85​
11(2.46GHz)​
140​
113​
133​
36(5.18GHz)​
491​
361​
356​
100(5.5Ghz)​
417​
404​
402​
161(5.80GHz)​
353​
327​
328​
Conclusion
Note: Make sure to compare performance between antennas and not channels. Performance across channels are affected by environment.
Saw the short antenna occasionally but I came across the super short antenna that looked really good on a website in korea. It was marketed for 2.4Ghz so I was worried about its performance for 5Ghz. So I performed various benchmarks utilizing iperf to compare performance. Since its marketed for 2.4Ghz I thought channel 161 would be hit hardest since its farthest from the optimal wavelength fraction. Channel 36 was hit the hardest and I went through the benchmark 2 more times but same results which is converse to what I expected from antennas advertised for 2.4ghz. I only use 5Ghz but I included 2.4Ghz cause I wanted to compare bluetooth performance. But performance impact was less than I thought. Geometric mean hit of 11.4% for the super short antenna and 7.4% for the short antenna.
Because I think people will ask links to antennas. They're for Korea so idk if it'll help tho.
Super short (20mm)
Short (30mm)
1337harcha
33
Cool stuff, one more step that would allow me to clear up the mess of wires. BTW the link for 30mm is a bit broken.
I tried searching aliexpress for similar stuff but only found one 30mm antenna with the wrong connector. Does anybody know where I can get this sent to Europe?
Lbibass
This was really well done! Personally, I noticed much worse connection speeds with a shorter antenna, but that was mainly because of the location of my router. If I rotate my case 90º, so it is on its front panel, the performance loss was negligible. I guess that's the advantage of having those long, wired antenna: you can move them so that they aren't interfered with by whatever is nearby.
