SG05 NAS
BaK
855
868
Hi
I've repurposed my first SFF build to make an SG05 Silverstone case a 2 bays NAS.
From this:
To this:
Motherboard: Asrock J3455-ITX
CPU: Intel Quadcore J3455 (imbedded)
GPU: Intel HD Graphics 500 (integrated)
RAM: 2x 4GB DDR3 SO-DIMM
Storage: 2x 4TB HDD + 64GB SSD
PSU: Silverstone 300W ST30SF V1
LAN: 1x GB
The 2nd HDD is attached to the upper one with 4 vibration dumpers, easy mod!
I just replaced the Silverstone front fan with a slimm 15mm one so that it doesn't touch the vibration dumper.
I want to keep it simple, so I am going to make a RAID 1 with the two 4TB HDDs on Ubuntu server.
I will then make regular backups on several external HDDs for safety.
Next step is to have a look at power consumption and maybe improve it by replacing the PSU with a Pico one.
hoon
Hey - nice work on this. I'm in the process of doing a similar build with an SG13 and relocated PSU with the end result being a "sideways" but vertical orientation.
Could you elaborate on how you mounted the PSU?
BaK
855
868
For the front PSU mod?
I used the two yellow screws to attach the PSU to the case, aligned into the holes of the 120mm front fan.
I don't have the blue ones on my ST30SF V1, this one is probably a new revision.
