SFF.Network [SFF Network] SilverStone announces the Raven RVZ01-E
Today SilverStone has announced the RVZ01-E, a variant of their RVZ01 slim console-style case that can fit an ATX power supply instead of just SFX. Press release below:
"SilverStone RVZ01-E is an evolution of the ground-breaking RAVEN Z RVZ01, a slim form factor case with tremendous capability. While maintaining the same volume size and appearance as the original model, the RVZ01-E’s interior was reworked to convert SFX power supply space into one for standard ATX (PS2) power supply. This amazing change came with little sacrifice as the case still has support for the biggest consumer graphics cards on the market with superb air cooling performance. Designed for use in either vertical or horizontal orientation, it can be placed comfortably in any space-constrained environment that requires a powerful PC. For those looking to build a slim form factor PC, the RVZ01-E’s ability to accommodate standard ATX power supply will help to open up more flexible and varied assembly option."
Read more here.
5,612
4,794
Still "just" a 14L case, although the 140-150mm PSU length limitation doesn't give you many options that SFX or SFX-L can't give you (soon).
iFreilicht
FlexATX Authority
Feb 28, 2015
3,243
2,359
freilite.com
So the dimensions weren't changed at all? In that case this is a logical variant of the previous interior. They wasted space so much in that case initially, they might just waste it on something helpful.
5,612
4,794
They did lose the 3,5" drive and slimline ODD support, although it's more of a personal choice if that's really a negative.
I still don't see why they made an ATX version when they'll have a huge SFX PSU lineup this year. Maybe too many people still don't know what SFX is.
iFreilicht
FlexATX Authority
Feb 28, 2015
3,243
2,359
freilite.com
As the RVZ01 is marketed as a no-compromise solution for full-size components that allows you to move most of your hardware from a big tower to a console-like case, they decrease the price of going SFF by the cost of an SFX PSU to some people.
Of course it's a trade-off. Either you get a new PSU and keep your old big HDD, or you reuse your existing PSU and buy a new drive.
5,612
4,794
Maybe, but I'm not convinced that many people "switch" cases midway through their build's lifetime. You'd also still need an mITX motherboard and compatible cooler (although 'boxed' works). Maybe it costs them a tiny fraction to do this and it's their way of doing market research.
