GPU SFF build help - GPU Full length spec. - actual length?
talalc
Hi
Trying to understand if GPU length on vendors the likes of MSI, Gigabyte, Asus, Inno3D etc. are whole card length including the baffle (outer bracket) or not.
Can anyone confirm if it refers to the whole length or just the actual card body?
Referring specifically to last generation nVidia/AMD cards.
Thanks!
msystems
661
1,169
AFaik Gpu length does not include the part of the bracket tab which extends outwards at 90 degrees, but it does begin with the face of the card's i/o to the end of the heatsink/shroud.
Reactions: Phuncz and riba2233
