Selecting aircooler for Louqe Ghost S1
Diegolrod
Hi,
I built a Louqe Ghost S1 with the next specs:
Ryzen 5 3600
Aorus X570I Pro Wifi
RTX 2070 super
Samsung Evo 970
Corsair vengeance 16GB
EVGA 650W
I chose a NH-L12s, however it didn't fit even though I bent it a bit and it was because of the motherboard.
So I will like to ask you all if you recommend me a good aircooler that could fit with this configuration and give good temperature with acceptable noise levels.
Thank you very much
neiru37
Yeah I'm pretty sure you're not bending it enough. Also try rotating the orientation as well as moving the fan outwards towards the opening of the C so that you can bend it some more without the middle part of the C hitting the fan. At first mine didn't fit as well when I had the opening of the C pointed up, but when I rotated it so that the opening of the C was pointing towards the PSU, then bending it some more to the point that the mounting screws didn't align up with the holes in the fin stack, I was able to fit it like a glove.
