dupp's sff pc| watercooled | 8700k @5.2 | 1080ti mini
Curiosity
Apr 30, 2016
713
832
Curious, it looks like you only have one stick of ram, might I ask why?
I feel like 2 sticks with nickel monarch heatspreaders might for the build a little better.
I'm very excited to see where this goes.
juldupp
twitch.tv
UPDATE#1
Res/pump combo
Me cutting the reservoir, lol.
Gpu block
juldupp
twitch.tv
Did you mod the GPU block to have the inlet and outlet there, or is this an option available on this block.
It is modded, took two attempts since I drilled the holes a tiny bit too big 1st try, had to use actual plexi-glue (which is Bits of plexiglass mixed with acetone) for the second attempt.
Reactions: fergunat000
Curiosity
Apr 30, 2016
713
832
How did/ are you planning to seal the channels above the fittings on the GPU block?
Super cool mod I never considered doing.
Are you using tubing as a stand? Really neat idea, I dig.
juldupp
twitch.tv
Heres the pump mod results:
Before - After
Needed a second one for parts.. broke this lil thingy down there. ?
juldupp
twitch.tv
Used crazy glue and a sheet of thin plastic.
You can barely see it, but its on this photo.
And yeah I am planning on using the tubing as the stand. ?
