Ryzen 2400G build planning
JosephEK
175
84
I'm going for a low profile build to lay under the monitor. So far I'm considering the ML-03b case for its ability to fit the cheaper and with more expandability mATX boards and for the ability to fit full ATX PSU so I can just recycle my current PSU.
One alternative I'm considering is to go ITX with either the ML05 case or is there a monitor rear-mounted case that has room for atleast the wraith stealth?
Thestarkiller32
152
102
https://pcpartpicker.com/b/cwYrxr
or somting like this?
https://www.inter-tech.de/products/case/mini-itx-nuc/mw-01
... at least the Noctua L9-i AM4 fits
JosephEK
175
84
I'm willing to humor the VESA mount strategy as opposed to the under-monitor one, but not at the cost of losing the ability to use the stock cooler so...
More than likely because of this I will simply stick to my under-monitor setup plans because It's just simpler. This still leaves the question:
ITX or mATX? The ITX boards for AM4 are more expensive.
7,425
If it was me (being broke a lot!), I'd go for the M-ATX build. It's more of a budget friendly stepping stone into SFF - being that you can re-use some of your components. In time, You can move to M-ITX :)
Reactions: Soul_Est
