RTX4000 Watercooling with Barrow 2070FE block
Lakimakromedia
25
If u are interested in watercooling RTX4000, Barrow block for 2070Fe is fair chose.
It's interfere with one electronic element. Everything else fits.
U need only cut one piece of block in marked place,
Block is too long for 5mm ;).
Ah, and also put those extra washers on back near GPU core. Possible shortcut with spring if u don't do it...
Cyberpunk2077
1080p with high setting max 50*C
Furmark
1080p don't go above 43*C
Loop with CPU 3950X, TX120+ xflow 240
Reactions: Kaji and Ca11idus
Alexander154
I have this same block and plan to put it on my RTX 4000 also, what tool did you use to shave down that one part? Will a dremel be strong enough?
Alexander154
I just got done doing this mod to the waterblock, i ended up just using a Dremel and the 3mm drill bit to chip away at the edge until there was enough space for the component to fit under it. Havent seen my temps go above 45c yet but the best part is, silence, finally :) I might try to sleeve the PCI-e connectors since theres no way to really hide them once the block is on.
