Image Credit – REVOCCASES
What started as inspiration from the Fractal North case, has turned into an absolutely stunning wood a metal SFF case from REVOCCASES. REVOCCASES had the metal custom machined and powder coated, and used a programmable router to create what I personally see as an organic take on brutalist design with the front wood panel. The design houses an ITX motherboard, SFX PSU, 2.5 inch SSD, and full size GPU in a vertical stack design with the motherboard at the bottom. Extremely large air coolers are supported, and GPU cooling can be supplemented with two fans at the front. A top exhaust fan can also be used to vent component heat.
Continue reading...
