Accessory Review - INTEHILL 1920×1200 portable 8.9" USB-C Touchscreen - supports HDR and FreeSync
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
My old portable monitor broke, so I was looking for some alternative... Finally decided to go really SFF and got a 8.9" USB-C Touchscreen from INTEHILL.
Technical Data:
  • IPS screen with 1920×1200 resolution, 60Hz
  • HDR Support
  • AMD FreeSync Support (48 ~ 60Hz)
  • Input: 1x mini-HDMI, 2x USB-C
  • 10 point touchscreen
  • VESA 75mm mounting holes
  • stereo speakers
  • 211 x 143 x 9.5 mm size
Size comparison:
The monitor comes with: manual, carbon fiber optic cover/stand, USB-C to C cable, USB-A to C cable, mini HDMI to HDMI cable, AC adapter
The chassis is made from brushed, black anodized aluminum
perfect fit for a small portable setup with a 230W TaoBao GAN adapter:
My impressions so far...
PRO
  • small and lightweight
  • great picture quality and pretty good brightness for that size
  • PD and DP over Type-C, so I only need to pack one cable
  • good build quality, no chemical smell from the protection cover
CON
  • FreeSync only via HDMI
  • getting the native resolution (1920×1200) to work via Type-C is a bit tricky (HDMI works fine though):
    you need to use a better cable and manually setting up 1920×1200 as custom resolution in your GPU control panel
  • speaker quality, well...
More info and product links:
BaK
855
868
Thanks for the review!
Interesting folding keyboard as well, first time I see one like this!
Reactions: REVOCCASES
Ricky Zeng
42
34
Technical Data:
  • HDR Support
  • stereo speakers
Size comparison:
PRO
CON
Nice Hades Canyon setup. Could you share a link for the aftermarket power adaptor from Taobao? I noticed it's much smaller than the OE adaptor. Is the adaptor any good to handle reasonably heavy load, e.g. 3D gaming / CAD modeling? Hades Canyon is quite power hungry for an NUC.
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
Here you go:
The Hades Canyon draws about 180 ~ 200W under full load (p95 & furmark combined). I have no long term experience with this adapter yet but didn't experience any issues so far.
Some impressions...
Pro:
  • less than half the size of a typical 230W brick
  • uses 4 real GAN Chips
  • real 230/240W output, OCP will kick in over 240W
Con:
  • DC cable is too thin for my taste, I would have preferred 14AWG or better
  • "only" 94% efficiency, a well optimized design could do better
  • like all GAN chargers, it gets quite toasty under high load
  • actual output voltage is 20.30VDC (not 19.5) and will drop to 19.8VDC at the barrel connector under load (because of the cable resistance)
Reactions: Bizanti
Ricky Zeng
42
34
Here you go:
Some impressions...
Pro:
Con:
Seems legit. Been looking for a good higher wattage DC adaptor. Thank you~
Nichronos
127
63
Try the Nexdock touch, it has its own integrated keyboard and both USB-C DisplayPort and HDMI inputs!
