Could you please recommend DC-DC convertor of 20v to 12v with 130W power (or 2 x 70W). I would like to use USB-C power supply (with Power Delivery trigger 20v) to power RTX 3050 (130W max).
Do you mean using it in tandem with one of the Usb-pd wall bricks? The Usb-c pd controller chip might not like the implementation because they have a strict amperage limit. Even with a 240w rated usb-c pd cable and proper "e-mark" 5a pd trigger it might cut out well before the rated wattage. If you have saw someone that had success doing this to a gpu or sffpc can you please share it? I'm very interested in seeing this done successfully.
For dc-dc PSU you can take a look at Pico Box and rGeek. They come in different ratings from 75w up to 300w and you need a usb-c to dc-barrel cable with integrated 5a 20v trigger.
It looks like I faced the issue in the past - do you know why it happens - sound strange to me: if PSU rated to provide 20v & 5A and I consume 20v and 4A - why PSU would cut out at this stage?
I dont know why for sure, but it has a microprocessor constantly monitoring the current and voltage. It seems like USB-pd chips are supposed to monitor and enforce load curves, because batteries need to be charged a certain way for maximum life.
I find this diagram on page 40 of Battery Charging Specification rev 1.2. Maybe there's some things in there that could explain it as there are lot of conditions and logic the charger is following.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
